Vacuum lines\emissions: Do I need to keep 'em all?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigJim85, Aug 3, 2002.
  1. BigJim85
    BigJim85 1/2 ton status
    Sep 7, 2000
    113
    Lakewood, Colorado
    Vacuum lines\\emissions: Do I need to keep \'em all?
    I'm in the process of installing a new 350 into my '85 Jimmy, replacing a tired, filthy, chared 305. I'm just wondering if I need to keep all those goddamned vacuum lines and emission bullshit, and if I can plug the vacuum tubes on the carb (QuadraJet, stock) and still get it to perform. Any help with this will be greatly appreciated.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Re: Vacuum lines\\emissions: Do I need to keep \'em all?
    I did on mine when I swapped in a 350 in place of the 305. You need to keep the essentials hooked up like vacuum advance, etc. If you have to get smog check you will not pass it if you pull everything off.
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I have an 83 from Colorado so I'm pretty sure we have the same 5 miles of emissions tubing under our hoods. I removed everything except the EGR, the smog, the exhaust injectors and the Cat. All the other thermoswitches, dash pots and other related garbageI dunno if it made it run any better but I didn't have to chase vacuum leaks anymore. /forums/images/icons/laugh.gif
  4. BigJim85
    Sep 7, 2000
    113
    Lakewood, Colorado
    Yeah, I figured I'd need the essentials. Hopefully the essentials weren't the lines that disintigrated into dust when they where removed. That sad 305 was abused by the previous owner, all the plastic on or near that engine was baked.
  5. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    I don't a digi camera anymore, but I can try to draw up a diagram of how mine is run if it'll help you out.
  6. BigJim85
    Sep 7, 2000
    113
    Lakewood, Colorado
    That would be downright kind of you. I'm sure I could figure it out, but every little bit helps since vacuum lines confuse the hell out of me.
  7. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Thanks a bunch! Now I hafta learn how to draw. Wheres my CAMERA! I really wish I could take a picture bcos I took every inch of tubing of the motor. Maybe if your not in a rush I can take regular pics and post them or even mail them to you. There might be a new total of 3 ft of vacuum lines. I even disconnected the cannister.
  8. BigJim85
    Sep 7, 2000
    113
    Lakewood, Colorado
    Hey, however you want to do it. This project will be taking longer than I planned. Cleaning a 1/4 inch of filth off of everything is a pain in the ass, even with mean degreaser. If your going to draw or send pics keep me posted. Thanks a bunch.
  9. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Well, I did a similar thing on myk 84. I eliminated a lot of the bullshit but kept the basics like the canister (out of a TBI Jimmy) and such. With 10' of 5/16 and 10' of 7/32 vacuum line I replaced every vacuum line under the hood except for a few vacuum switches in which I just plugged the ports off I didn't use anymore.
    If you stare at your emissions sticker long enough you can figure it out. It took me about an hour and a half.
