Vacuum modulator line
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cj7jeep81, Mar 13, 2003.
  1. cj7jeep81
    cj7jeep81 1/2 ton status
    Feb 17, 2003
    110
    Indiana
    I need to replace the vacuum line going to my modulator (and possibly the modulator itself). Should I just use regular vacuum hose, or should I get something different?
  2. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    yea vaccume hose sould be fine. if your modulator is working right it should never tough tranny fluid just hold a vacume. i think the mobulator was 10 bucks or so for my TH350
  3. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    I saw autozone had the modulator for $10, but it looks like it might be a pain in the a$$ to replace. I know I need a new line, so I thought I would replace it first. Then when I pull the engine in a few months, I will replace the modulator.
  4. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    The modulator is easy to change. Just remove 1 bolt from the holddown & it slides out. When replacing the vac line, you can use rubber, just keep it away from the exhaust. Also there is a raised loop where it connects to the intake for a reason...... this is to help prevent fuel vapors from traveling down the vacuum line to the modulator which will cause the diaphragm to go bad. Keep some type of loop here for this reason.
  5. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    Ok, thanks for all the help. I will try to work on it this weekend.
