vacuum modulator on tranny???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Intense Blue, Mar 6, 2002.
  1. Intense Blue
    Intense Blue Registered Member
    Dec 2, 2001
    49
    i have a 87 k5 w/350 motor, 700r4 tranny and all is factory. i am looking for the vacuum modulator on the tranny.my truck is shifting a little slow and was thinking maybe the vacuum line went bad, but i dont seem to see one. also there is sensor on the tranny about in the middle of it on the drivers side. what does this do?????
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I don't know 700's very well at all...
    But i'm pretty sure that only the TH350's and 400's have a vaccum line going to the transmission modulator. 700's won't have that.
    As for the sensor?
    What is is where one wire could hook on to?
    maybe the reverse lights switch?
    lockup torque converter?
    Neutral safety switch? Temp gauge?
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    no vacume on a 700r.
    and the wires are for the locking convertor i think. i am almost posative of it.
    Grant
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    No vacume modulator on 700r4s . Shift points are adjusted with the TV (throttle valve) cable. its the cable that goes from the TBI/carb to the trans.
    Do a search on" TV cable adjustment" the are a bunch of posts about it and how to do it.
    The wires that go into the trans on the middle of drivers side are for the electric torque convertor lock up. I think there is also a sensor that tells the computer that the tranny is in OD around there somewhere also.
  5. Intense Blue
    Dec 2, 2001
    49
    hey thanks alot guys....
  6. Intense Blue
    Dec 2, 2001
    49
    the other thing along with this was that i got a code 24...vehicle speed sensor.....and my speedometer does not work, i unplugged it(mech.cable in the back) and plugged it back in and still does not work. i wonder if the gauge is bad now, is the VSS (vehicle speed sensor) located inside the dash cluster???
