vacuum pump is spitting oil.
Discussion in 'The Garage' started by general blaze, Jan 18, 2007.
  1. general blaze
    general blaze 1/2 ton status
    Sep 4, 2005
    128
    ca
    why is this happening. i pulled the vacuum pump off the shaft that drops down into the engine block and there is oil all over the place. oil seems to be coming up the shaft and entering the pump and blowig thru it and leaking all over my motor. the oil is affecting the starter and i am already in need of my third starter in as many months. i am surching online for pumps online but it seems to only come with the pump and not the shaft. my pump seems to work fine with the engine running it creates suction and i have no problems in that area. but oil still comes out the left side of the pump. any one have this problem and what part should i replace the pump or the shaft.
  2. dremu
    Feb 27, 2000
    15,952
    443
    East of San Francisco
    I'll assume you're talking about the 6.2/6.5L diesel... yes?
    The vac pump fits in like a dizzy ... donno if there's supposed to be a gasket there, or is the oil coming THROUGH the pump?
    -- A
  3. general blaze
    Sep 4, 2005
    128
    ca
    ya it is coming up from the block thru the shaft of the pump then exits the left side of the pump where the actual pump is not the shaft. the pump is two pieces the shaft piece and the round pump assembly. i pulled them apart today and there was oil in the pump and all over the inside of the shaft where they meet up. i dont know what side i need to buy the pump or the shaft.
    ya 6.2 diesl
