Vacuum Questions?
Discussion in '1982-Present GM Diesel' started by OffRoader93, Apr 5, 2005.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    What vacuum accessorys are necessary to keep on a 6.2 diesel. Any help would be great. Thanks.
    Brenton
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    My '79 doesn't use any vacuum accessories after converting over to 6.2L. I just replaced the vacuum brake booster with a hydroboost.
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    If equipped, the A/C controls would be about all you need the vacuum pump to do.
  4. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    If running a TH400 behind the 6.2L, you'll also need a vacuum supply to control the tranny shift points.
    Casey
