vacuum switch install
Discussion in 'The Garage' started by Big GMC truck, Jan 2, 2006.
  1. Big GMC truck
    Big GMC truck Registered Member
    Aug 23, 2005
    73
    California
    I'm replacing a vacuum switch that is located on my water outlet. Will coolant come out when I take out the switch? Do I have to drain the coolant? Do I have to put anything on the threads of the switch? Thanks
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Coolant will come out. I first coat the threads of the new sensor with Permatex Form-a-gasket and then just thread it in quickly after removing the old one. If you do it right, you'll only lose a few ounces of coolant. :)
  3. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    If you are talking about the thermal vacuum switch on the top of the thermostat housing, should only lose a couple of drops of coolant. I used teflon tape on my threads-not sure what GM recommends but didn't seem to leak afterwards.
