vacuum switch
Discussion in '1982-Present GM Diesel' started by René, Aug 5, 2002.
  1. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Which function has the vacuum switch at the fuel filter?
  2. Hans_de_Wilt
    Hans_de_Wilt Registered Member
    Feb 5, 2001
    9
    On my '84 CUCV it's only for the diagnose connector under the dash (according the wiring diagram).
    Hans. NL http://move.to/chevy4x4
  3. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Is it possible that the part calls itself also Restriction SWITCH?
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I <font color="blue">think</font color> that restriction sender should trigger the (change) fuel filter light on the dash. CUCV's didn't have the light but the sender was wired to the STE-ICE connector for diagnosis.
  5. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Thus I imagined that. Thats probably only to reminding lazy people of the changing intervals. Before a few days, I have had the pleasure to refuel a dirty fuel. The warning lamp lit up, but the engine ran completely normally. A few minutes after the warning lamp gone out, the engine began too run hardly and had power loss. This play went now so for a long time till I changed the filter. Its probably like that, that I can do without the small lamp
    Thanks for the information.
  6. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    As water builds up in the filter, the flow of fuel will become restricted. I think the pressure switch can turn on the water in fuel light as a backup to the water level detector. Something like that. It's a backup to the water detector. I've heard many stories about the pressure switches going bad and having terrible reliability so people were jsut unplugging them.
