vague steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NorthernRedNeck, Apr 6, 2002.
  1. NorthernRedNeck
    NorthernRedNeck Registered Member
    Apr 19, 2001
    36
    Ontario, Canda
    Hoping somebody can help me out here....a friend of mine brought by an 87 Blazer, 350 tbi, 700, 135000 miles, 10bolts, and 31's. We took it out for a drive and the steering is extremely "vague" you must saw on the wheel alot more than what u should have to to get much of any response. Then we took mine out just for shits and giggles to make sure it wasn't my imagination or a case of err...K5 envy lol but my 89 was extremely tighter. We looked over the truck and it doesn't look like it has ever plowed and the frame appears in excellent condition as it has been under-oiled since new. The truck also has just went through inspection so all of the front-end pieces are tight. The only thing we can really come up with is that the steering box may be worn out. Any ideas as to what this ailment may be?
  2. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    Just a guess, but on mine if the crossmember becomes loose my steering becomes sloppy, other than that just make sure that you check the normal stuff like wheel bearing play, ball joints, also check the play in the steering column..
    good luck
    TJ...
  3. chevyuser
    chevyuser Registered Member
    Mar 27, 2002
    15
    Ingolstadt ( Home of AUDI), Germany
    Hi Chevydrivers,
    I have a very similiar Problem on my CUCV, if i turn sharp left like when i go left on a crossway, then when I want to go straight, the truck turns right a little just like the axle would be out of direction.then after some harder short steering turns, it goes straight ahead again.
    So if it would be my Brakes, it would stop turning right when I depress the brake pedal but that doesnt have any effect.So i checked all bearrings and ball joints and found the one which is located on the connection from the steering box to the left wheel near to the left wheel is a little bit bad but not very bad, although I dont think it would have an effect like this if it was worn out?
    I cant locate any trace that a moving axle would leave on the springs and also the spring mounting rubbers are not worn out.
    The springs are freshly oiled so they can move easy on each other.
    I hope anyone of you got some suggestions for me what causes my probs.....
    Regards, Chevyuser
  4. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    have you tried simply adjusting the steering box? They aren't always worn out, sometimes they just need a little adjusting. Just loosen the nut on top of the box and use an allen wrench to drive the bolt down untill it bottoms, then back it off a little (1/4 turn or so) and tighten the nut back down.
