Valve Adjustment question...which one is the intake or exhaust..
Discussion in 'The Garage' started by jakeslim, Oct 2, 2004.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Ok, I need to double check my valve adjustment after changing heads. Below is the procedure to adjust but I'm not
    sure which is the intake for #1. Lets say I'm facing the engine from front, is the closest lifter to me the intake?
    with #1 cylinder Intake Valve at full valve lift .... Adjust #6 Intake Valve
    with #8 cylinder Intake Valve at full valve lift .... Adjust #5 Intake Valve
    with #4 cylinder Intake Valve at full valve lift .... Adjust #7 Intake Valve
    with #3 cylinder Intake Valve at full valve lift .... Adjust #2 Intake Valve
    with #6 cylinder Intake Valve at full valve lift .... Adjust #1 Intake Valve
    with #5 cylinder Intake Valve at full valve lift .... Adjust #8 Intake Valve
    with #7 cylinder Intake Valve at full valve lift .... Adjust #4 Intake Valve
    with #2 cylinder Intake Valve at full valve lift .... Adjust #3 Intake Valve
  2. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    Just look at your exhaust manifold. You can plainly see which vavles lines up with it.
    good luck /forums/images/graemlins/peace.gif
    bob
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    They go eiieeiie
  4. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    They go eiieeiie
    i amlost started singing old mcdonald /forums/images/graemlins/histerical.gif
    Ok, is the eiieeiie fromm the front on both sides or from the drivers side and reverse order from the passenger side... /forums/images/graemlins/doah.gif
  5. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Both sides, back to front or front to back, the same. /forums/images/graemlins/thumb.gif
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    It's a palindrome... /forums/images/graemlins/tongue.gif
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i found it easier to have someone bump the starter until both valves on #1 were closed, then bump it again to make sure they don't move, then do those, then repeat for 357 then 2468
  8. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    yeah, I got it done. I had my girlfriend bump the motor while I followed the pattern to tighten above. Before I put the intake back on, I bumped it to #1 TDC so life remains easier /forums/images/graemlins/waytogo.gif
    thanks for all the help
