valve adjustment
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Oct 13, 2000.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Can anyone refresh my memory on adjusting the valves on the a 350. Think it is the same proceedure on all GM motors. Think you can do it while engine is running, tighten them down till they stop clattering then back off 1/2 turn or something to that effect.
    Don't you buy no ugly truck!
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I beleive its tighten until they stop clattering and then a half a turn more. I'm sure someone has the exact procedure. [​IMG]
    Rene
  3. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Back off till clattering, then tighten till just no clattering, then I go 1/4 of a turn more, but the manual will tell you more. When I am building a new engine, I tighten the rockers in this way (tighten till all up and down slack is removed), then go 1/4-1/3 turn tighter. I fire the engine up and never have to adjust while running!!!
    ken
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, I've only had this jimmy about 2 months and I had to lay it to the floor the other day adn the damn valves stated to dance the the nashville symphony. May be cheap gas but, I don't think it would hurt to get in there and make sure. Whatch' y'all think?
  5. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Valve chattering would be noticeable at idle. When you romped on it and it made that sound it's from pre-ignition (pinging). Once you adjust the valves on a chevy you shouldn't have to adjust them again. If you do then the cam lobes are getting flattened or a stud is starting to pull out. Check timing and if it's not chattering at idle, then adjust your timing to get the oinging out.
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well don't I feel like a dumba**. Thanks man. I knew that but its just been so long since I've tinkered with cars. All that knowledge has slipped off to the back of my brain somewhere.
  7. bart
    bart Registered Member
    Mar 15, 2000
    69
    Eastern PA
    on a newly installed valvetrain, back off the adjusting nut on the rocker all the way, position the cylinder at TDC (both valves closed), while spinning the pushrod between two fingers, tighten down the nut until you feel resistance on the pushrod, then tighten 1 turn +/- 1/4 turn..so that's 3/4 to 1 and 1/4 turns tight. Do this only once..if you have collapsed a lifter, you will need to let it return in order to not hold valves open which is most noticeable by a backfire or a miss and noise in the exhaust.
    Bart
  8. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Would that be a miss under load? Backfire, not immediatly but say when lugging (4 speed)? Just curious (yeah right[​IMG])
    Rene
  9. bart
    Mar 15, 2000
    69
    Eastern PA
    that would be a miss all the time if the valve doesn't close all the way..even just a tiny bit the cylinder will never draw a vacuum and thus never take in an air/fuel charge..
    bart
