Valve Cover Gaskets
Discussion in 'The Garage' started by daleearnhardt01, May 30, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Looks like the Jimmy needs some new valve cover gaskets. Any particular kind as opposed to another. I work at Autozone so I have access to Fel-Pro. Is the job pretty straight foward as far as gettin the covers off, like do I have to move anything big out of the way? Doesnt look like it but just want to make sure. /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Yep, pull the old ones off and slap a new gasket in. May have to move a vaccumm line. Should have no problems. /forums/images/graemlins/thumb.gif
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    as far as gaskets go u can't beat the ones that are made out of the rubber like stuff & have the metal in side them. kinda pricey but u can use them over & over.
  4. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    i went with the cork ones the last time. bit of gasket maker on both sides and not one drop has leaked.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Your profile shows that you have a 90 model. Does it still have the centerbolt heads??? The gaskets on those things seem to last forever since they're made out of a silicone rubber. Are you sure that's where the leak is coming from?
  6. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Well the whole left side of the motor is wet from oil. I noticed it today when I was under it changing the oil. Im just assuming its the vc gaskets. The motor has 177k on it. Whatcha think?
    Opps forgot to answer your original question..Yes it has center bolt heads..
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There is only one name in gaskets. Fel-Pro.
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Check to make sure that the bolts are tight. /forums/images/graemlins/wink.gif Those gaskets are reusable and will last a very long time as long as they haven't been damaged. The sealing surface on the centerbolt heads is also raised considerably higher than on the early style heads, to prevent oil from pooling against the gasket area. It's pretty rare for them to leak.
    Also:
    Did you see oil on the upper part of the engine also, or just on the bottom?
  10. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Yeah I meant standing up under truck I noticed oil all on the side of the block and when I put the truck back down I looked closer and you can see it on top of the covers and going down the side of the motor. Its worse on the left side than the right. Ill tighten them up tommorow and see what happens. Thanks for the help man.
  11. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Be sure not to overtighten
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    GM even protected us from that issue with the center bolt valve cover design. The bolts are designed so that they stop going into the head before they can crush/bend the valve cover or damage the gasket. /forums/images/graemlins/thumb.gif
  13. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    So does it sound like its the valve covers? One member mentioned blow-by and I can understand with 177k on the clock its possible but would the whole side of the motor be covered in oil? Looks like some is coming off the back side too, the inspection cover was wet as well. There is no loss in power or anything of that nature. I pulled the oil cap off and couldnt feel much of anything against my hand with the motor running? /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  14. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Get some good degreaser castrol or such.
    Go to car wash.
    Hose engine with degreser and let sit.
    wash off engine.
    Drive for a bit and see where the leak is coming from.
    Or toss in some oil dye and run it and see where it is coming from.
  15. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Oil dripping from the inpection cover could be coming from the rear main seal or from a leak at the rear of the intake manifold.
    Cleaning the engine and then checking to see where the leak originates is excellent advice. /forums/images/graemlins/cool.gif
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Changing the rear main seal on that engine is a cinch.........once you get the transmission removed. /forums/images/graemlins/yikes.gif
  17. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
    dont waste your money on the cork gaskets....pieces of [darn]! buy the rubber ones, youll be very happy in the long run /forums/images/graemlins/truck.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/thumb.gif
  18. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    He has centerbolt valve covers. The gaskets are made from a very soft and pliable silicone rubber that fits into a pocket in the edges of the cover, which holds them in place. I'd venture to guess that no one even makes a cork gasket for those heads. /forums/images/graemlins/thumb.gif
