Valve Cover Help
Discussion in 'The Garage' started by ARAMP1, Dec 10, 2006.
  1. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    My old stock stamped valve covers on my 454 were leaking a bit and instead of just replacing the gasket, I decided to buy a set of O ring type valve covers.
    I bought them on e-bay for around $20 which is what used sets seemed to be going for. Anyway, they came with the used gasket (which looked to be in good shape), so I decided to put them on and they leaked like a sieve. Okay, I decided to buy new gaskets. That helped, but they were still leaking. Next step was to use some RTV. I used a thin coat and again it helped, but the problem was still not fixed. Alright, if a little is good, more is better. I decided to cake on the RTV and they’re still leaking.
    The valve covers are not cracked or warped at all and they heads look normal. Any ideas what I could be doing wrong? :confused:
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,993
    130
    How well did you prep the head surface and valve cover surface? Probably your problem.
  3. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I definitely cleaned all of the old gasket material off. Other than that, there isn't much prep.
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Scrub the mounting surface down with carb cleaner, to get rid of oil residue, then try again.
  5. 1977k5
    May 26, 2003
    9,993
    130
    If you don't use a solvent that doesn't leave a residue (brake cleaner, carb cleaner, laquer thinner, etc.) you will have trouble with RTV.
  6. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Sorry, should have specified. I did use brake cleaner. The mating surfaces are clean enough to eat off of yet it still leaks. Are there some heads/covers that weren't compatable?
  7. Dr. Morgenstern
    Dr. Morgenstern Registered Member
    Apr 12, 2006
    92
    Tecumseh, Ontario (across from Detroit, Mi)
    What year are the heads? Newer cast aluminum gm covers don't work on the Mark IV heads unless they've had some milling done to the gasket mating surface.
  8. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Have the bolts been tightned down really tight a couple of times. That can ruin the valve covers. It honostly sounds like you may have some warpage in your valve covers. Sometimes its really hard to see.
  9. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    If this is true, it would explain it. The truck is a 1990 with the origional heads and the covers are from a 94-95 (I think). Can you explain the milling?
  10. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    I've had no issues at all with the GMPP covers on my 85.
