valve cover oil leaks
Discussion in 'The Garage' started by dukhuntr5, Apr 15, 2007.
  1. dukhuntr5
    dukhuntr5 Registered Member
    Aug 22, 2006
    7
    southaven,mississippi
    Surely someone on the forum has suffered with valve cover oil leaks on a pre-86 small block. Ive tried different valve covers, gaskets and assorted methods over the years. They always seem to leak at the rear of the cover. Any help would be appreciated.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    extreme cleanliness, make sure ALL surfaces are VERY clean, after scraping off the old gasket material, take a rag, spray some brake cleaner on it, then wipe down the head surface, so to rid it of any oil coating...
    Take the valve covers, scrape them clean as well, and also use the brake cleaner to clean the surface of any oil coating,
    use a very thin coat of high temp black RTV on the valve cover only, place the gasket on the valve cover only, place it centered with all holes, set it on the gasket surface on the ground for awhile until the gasket sets up so it won't move while putting it on the head....
    once it's set up, install them on the head, no RTV on that surface, the gasket will seat to the surface when it heats up.
    I do this even with chrome valve covers, and don't have any issues with leakage, and most chrome covers are hard to get sealed.
    if you don't have them, try using the long spreader bars to assist with dispersing the torque of the bolts over the valve cover edges.
  3. Randy92782
    Randy92782 1 ton status
    Mar 25, 2007
    16,287
    Arcadia, MO
    i do the same method as 4xcrazy but i also hit the holes on the valve cover with a ball peen hammer.(from the top kinda flares it out) i was told it helps seat round the hole. idk. worked
  4. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    dont overtorque the bolts, slightly tight with a small 1/4 ratchet. maybe 10 foot/pounds. rubber gaskets work well too.
  5. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    Ive had lots of trouble getting my valve covers to seal. what worked for me is like 4xcrazy said or some of those rubber gaskets with the steel inserts. the steel inserts keep them from losing their shape or blowing out.
  6. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    huh thats weird..i CANNOT get the rubber gaskets to seal but always get my cork gaskets too. idk lol
  7. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    dont over torque the bolts, guess thats the beauty of center bolts lol
  8. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Yeah, i have never had any luck with the rubber ones either,,,maybe they were cheap or something, but i just stick with the cork, no issues with them.
