Valve cover?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tybee, Jul 5, 2001.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Whats the best way to seal a valve cover? Just the cork or cork and permatex or just permatex?
    Theres nothing like fiddling with my Jimmy! 1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31 x10.50 x 15
  2. Flipper
    Flipper Registered Member
    Oct 19, 2000
    38
    West of Mpls. MN
    clean valvecover and apply silicone to valvecover gluing cover and gasket .
    let dry by puting vavecover on flat surface and letting the weight make a good pre-load to stick
    don't forget to make bolt holes line up-
    Flip
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    You could go ether way The blue stuff is ok untill you go to pull off the valve cover, I like the rubber gasket myself. But what it comes down to is whatever keeps the cover from leaking is good to go.
    Lost? i'm not lost i'm just disorienated
    Cethern@interfold.com
  4. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Thanks for your responses, I replaced the heads a little while ago and one of the valve covers leaks and I only wanna pull the injector lines off once.
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    After you clean the cover up you might want to wipe it down with alcohol to get all of the oil off before you apply the sealer. Seems to help and lets you know about all of those little cuts on your hands at the same time!
    Smitty
