valve cover
Discussion in 'The Garage' started by DUKE, Jul 31, 2002.
  1. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    I grabed a beautifull pair of valve covers off a older suburban at the local yard, and diddnt even realize it untill i started cleaning em up at home that they didnt have any holes in em, for breathersm, pcv, or oil fill types of things. Anyway is any of that crap needed? And if not, how then would you put oil in it? Or was the fansy valve covers what brought this burb to the yard?
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    If you rig is using a PCV valve, you'd better drill the new cover out and buy a grommet. DOn't go without a PCV valve or a breather of some sort. And if there's no way to put oil in the motor, what are you gonna do if you're down a litre? /forums/images/icons/wink.gif
  3. eds77k5
    eds77k5 1/2 ton status
    Oct 19, 2001
    383
    washington state
    i had to use a hole saw to drill the holes for the oil filler and pcv on mine when i got them, the parts guy said there were knock outs for them but they didnt knock out and i didnt want to beat up a nice set of covers, so i drilled instead
