valve covers for Center Bolt heads?
Discussion in 'The Garage' started by sled_dog, Aug 2, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what valve covers do you have on your center bolt heads? Gonna put on roller rockers so I'm pretty certain I need new covers. wasn't going to bother but a few rockers are cracked so I'm not going to chance that.
  2. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    I know proform makes some high enough for roller rockers. About $140 I think. I was looking around when I was thinking of going vortec heads
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Horsepower TV showed some Proform steel ones, said they were damn cheap, and they would clear rollers. But Proforms site says they are still making the site and I can't find them on Jegs or Summit.
  4. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    those seem to be the ones they showed, but they said a lot cheaper than that /forums/images/graemlins/yikes.gif
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    yeh i heard em say cheap, and i knew that was bs, cause I knew they were pretty expensive.
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Trick flow makes center bolt to early style valve cover adapters. They give you a lot more options in valve covers.
    I think come set up for stud girdles too. Might need to check if they fit roler rockers.
    I'm sure Summit or Jegs sells them
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    GM themselves sells the adaptors too, but they cost as much as the Valve covers I would like to get /forums/images/graemlins/wink.gif
  10. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    You mean these things?
    Ouch, $100 for the adapter and you still haven't gotten yourself any valve covers /forums/images/graemlins/yikes.gif
  11. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    If you are still running an AC compressor, the tall covers will interfere. I went with only roller tips and bought some cast aluminum covers at a show for $50.
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    probably just going to go with roller tips but probably still get those covers. Never had A/C.
  13. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I dont know if you have looked at your other post yet but in the pictures I have proforms polished aluminum center bolt valve covers. They are tall too, the ones they list in their catalog are the short ones but they offer tall ones too in the same style with the bowtie stamped on the top. I am also running full roller rockers in there too, I really like the proforms they look nice, but thats only cause I am not really to fond of the chrome jobbers. Heres a link anyways to my motor so you can see them.
    Stroker 1
    Stroker 2
    They are not the best pics of the valve covers but they have a red bowtie engraved on them and they say chevrolet. If you would like better pics then let me know and I could take some better ones.
  14. dyeager535
    26,980
    Running stock centerbolts with 1.52 comp pro magnums.
    Little bit of time with a grinder and they fit.
    Only clearance issue with the rollers is that they are wider at the trunnion than stock rockers. (fat center section if you will)
    The stock centerbolt covers use reinforcing pieces welded across the center where each bolt hole is, and for strength, the lower lip of those is bent over. I took just a bit of that lip off where the trunnions were giving me issues, and they have been run on my truck with no problems.
    Since the trunnion on the rollers doesn't move, there is no clearance issue associated with the valve train running. Well, let me re-phrase that. On self aligning rockers the trunnion won't move, or VERY little twisting. In any case, after about 500 miles, there is no wear on my rockers or covers.
    Unless you go crazy with lift or ratio, I don't see how you could have any problem.
