Valve covers wont stop leaking
Discussion in 'The Garage' started by ntx78k5, Oct 17, 2005.
  1. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    Ive used three different sets of gaskets, RTV silicone and the rubber gaskets with the metal core and they wont stop leaking.
    its a 350V8 with stock valve covers, is there a real simple trick I am missing???
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    are you using just bolts? or some of the fancy wingnut things? are the gasket fitting the gasket lip properly?
  3. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    are the covers straight? and how tight are you getting the bolts? a lot of people over tighten them
  4. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    also are your covers stamped steel? they are real bad about getting dimples where the blot hole is from over tighting them
  5. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    most likely overtightening like has been mentioned before.
  6. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
    Using stock bolts, news hold downs and they are the original stamp steel. They look striaght with no dimples. Are they supposed to be tightened in a specific pattern? torged to certain ftlbs?
  7. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    dry it all off and try some permatex tac-n-seal little white can. the stuff is red in color and smells like some good stuff:screwy: if you know what i mean. aply to heads and v/c and install with just that and gasket.
    this stuff is super stickky and grips stuff good.
  8. wildbilzrydn
    wildbilzrydn 1/2 ton status
    Jun 27, 2005
    118
    Joliet, IL
    Make sure the oil is draining back properly from the rocker area. The gaskets in a chevy aren't designed to do anything other than contain the mist. Thats the problem with mine now.
  9. ntx78k5
    Oct 22, 2004
    166
    Home of the Rangers
    I actually have some of that stuff and it smells real good. will try that out.
  10. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    The best cure I found for leaking sbc covers was to replace them with cast aluminum covers. They're rigid enough and flat enough to provide even clamping force along the entire gasket, not just near the bolts.
    I ended up buying some old Edelbrock cast covers at a swap meet...
    Rene
  11. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    or swap to center bolt heads.
    ryan
  12. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Ya that permatex tac-n-seal worked for me. Smells good like mentioned as well. My only question is. In the PCV there is a little ball isn't there. I replaced mine but there was no little ball :doah: . I have been driving it for months since and havn't had any problems, so where is the ball ? hehe
  13. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    leave them kinda loose always works lol
  14. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    If you have blowby like crazy, it could be pressurizing the case and blowing out the gaskets.
