Valve guide seals?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CBLAZER81, Jul 16, 2000.
  1. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    The Blazer started smoking about a month ago.I finally took it out to my shop and did a compression test on it.The cylinders were all right around 95p.s.i..This tells me that the rings are ok and I'm thinking it's the valve guide seals.Does this sound right?
    It felt AWSOME to drive it again after letting it sit for a month.Had to learn how to drive it all over again.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I had the same problem..it would let out a puff of smoke when I would start it in the morning. I had to get my valve guides adjusted, it did not take long and It did not smoke afterwards. If it is a good mechanic I would have to say that is the problem..but the oil can get in around worn piston rings too, and other fun to get at places...
