valve hit piston why?????
Discussion in 'The Garage' started by beefy blazer, Feb 6, 2007.
  1. beefy blazer
    beefy blazer Registered Member
    May 28, 2006
    7
    canada
    i just built a 383 stroker, flat tops,282 degrees@.50 and.495 valve lift, its a solid flat tappet cam . i checked the piston head to valve clearence and it was well within specs, so why would have #4 exhaust valve have hit the piston?it wasnt a hard hit(piston is still fine) but the valve was bent which in turn ruined the seat and the brand new bronze guide. any insight or advice would be quite appreicated.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    valve lash too tight jumps to mind. If it was too tight the rocker was pushing the valve farther off of the seat and tap a tap tap. What is "fine valve clearance" in your book? valve relief pistons? Is the cam advanced or retarded from the manufacturer specifications?
    are you sure it is 282 degrees @ .050"? That is an EXTREMELY agressive camshaft with huge overlap, that likely leaves the valve very close to the piston at any given point.
  3. SLOK5
    SLOK5 1/2 ton status
    Apr 25, 2005
    216
    SAN LUIS OBISPO CA
    Either something is off with your lift ratio / spring rate or timing ........... But there could be a number of other factors .... piston height, rod size different....
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The obvious answer is they tried to occupy the same space at the same time:D. Other than that I dont know but I am curious.
    Ira
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    timing belt let loose?
    sorry couldn't resist
  6. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    If only one valve hit, it is not a valve timing thing. The valve lash would have to be rediculously tight to cause the problem. My guess is that the valve got stuck in the guide and did not close.
  7. goldwing2000
    goldwing2000 Guest
    It happens with chains, too. I had a Caddy lose a chain and it smacked all 8 intakes and 3 or 4 exhausts.
    But yeah... if it was just one valve, then the problem is more than likely isolated to that cyl. Either a sticky valve or a weak/busted spring or something.
  8. superwrench
    superwrench Registered Member
    Feb 2, 2007
    20
    Little Rock, IA.
    Baja Blazer is right, If it was only one valve it is isolated to that cylinder. Maybe the valve guide was not lubricated enough, or to tight to start with. I doubt it was because the lash was to tight.
  9. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    One obvious cause that comes to mind is valve float. You didn't happen to wind it real tight, did you?
  10. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    lifter?..
    I've seen hydraulic lifters lose the little lock clip that holds the push rod cup in them,and then they pump up beyond normal limits,that can bend push rods or valves..weak or broken valve springs,a sticky valve,or tight guides can let the valve get "kissed" too,especially in motors with high lift cams and close piston to valve clearances..valve can't "snap shut" fast enough,and the piston whacks it..:crazy:
  11. goldwing2000
    goldwing2000 Guest
    Probably not the lifters.
  12. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    I have seen my share of bad cams. ground off center from where they should be.
