Valve Lifters
Discussion in '1982-Present GM Diesel' started by ae864cd, Nov 28, 2001.
  1. ae864cd
    ae864cd Registered Member
    Sep 26, 2001
    22
    Orange County California
    Do you have to remove the heads when changing the valve lifters?
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    No, you can take off the valve covers and take off the rocker arms, then the pushrods, then take off the intake, and the valley pan and you should be able to get them out easily.
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  3. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    Valley pan?6.2 diesel that was in pieces in our garage last year didn't have valley pan.If I'm not completely wrong,you have to take off the heads in order to change lifters.
    I'm too lazy to stick shift,that's why I prefer autotranny.
  4. BlueBlazer
    Feb 15, 2001
    1,940
    I just doublechecked and according to the Haynes manual you dont need to remove the heads, just the rockers, pushrods, etc. To be honest ive never done this before on a 6.2, but I figured that there is a valley pan because you have the intake with the injector pump below it so I figured there is a valley pan to seal the lifter area. Now, I assume that if you take of the manifold and the injector pump and then whatever covers the lifter area after having taken the rockers and pushrods out you should be able to take the lifters out just like a gas motor. Im hoping some of the guys who have done this i.e. dieseldan could elaborate on this a bit more. Sorry if I have given any misinformation, Ill try not to let it happen again.
  5. 4x4_76
    Jul 22, 2001
    628
    Ylämaa, Finland
    On the heads there is holes where the pushrods come trough,but the hole is small,so the lifter don't fit there.Also,lifters are hold in place with retainer that is bolted to block,and bolts are under the head.I once tried to change couple of bad lifters,but then realized that I have to remove heads.Injector pump can stay in place,though.
  6. BlueBlazer
    Feb 15, 2001
    1,940
    OK, I just looked at another pic and it looks like you describe, but then there is another pic that looks like a gas motor setup. Sorry for any confusion I have caused.
  7. 4x4_76
    Jul 22, 2001
    628
    Ylämaa, Finland
    No harm done.We all make mistakes but that's just life.
