valve seals
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kristoffer, Jul 26, 2001.
  1. kristoffer
    kristoffer Registered Member
    May 21, 2001
    32
    Norway
    hello i wonder is it hard to change the valve seals on a 350, never done it before. how do i do it?
    please help..
    Kristoffer
    1977 blazer k5 cheyene
    Sory for my bad english! :)
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Never done it but have heard all about it.
    First your gonna need to take the valve covers off, then your gonna need to get a fitting that will screw into the spark plug holes that hooks to an air line from the air compressor.
    And your gonna need a valve spring compression tool to get the spring retainers off.
    You start on one, take the plug out, remove the inition coil wire and turn the motor over till that piston is all the way to the top. Insert the air fitting, apply air, then remove the spring retainer and spring then the valves will be exposed along with the seals. Then you take the old seals out and insert the new ones. I have always heard to use the umbrella shaped ones, adn you'll never have to worry about it again, providing this motor is all stock. Then move to the next cylinder
    Did you say I have monkeys flying outta my butt
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Pay particular attention to this part: "turn the motor over till that piston is all the way to the top". Do NOT remove the spring retainer until the piston for that cylinder is at the top of its stroke. Even though the air pressure from the compressor is holding the valves closed, it is still possible to bump the valve stem hard enough to cause it to open. With the retainer removed, this means that the valve will drop into the cylinder. If the piston is at the bottom of it's stroke when this happens you will get to learn how much work it is to remove the head. [​IMG]
  4. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    It's not bad untill I got to the drivers side by the vacum booster in the rear, it's just kinda tight to get your valve spring compresser in there. But overall it's not a bad job.(unless you drop a valve)
    <a target="_blank" href=http://www.community.webshots.com/user/wheelininco>www.community.webshots.com/user/wheelininco</a>
    " Wider IS Better!!!"
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Good point HAIR-E! I thought I had everything in order there, but I hsould have pointed that out. But once again you are here to clean up after me!![​IMG]
    Did you say I have monkeys flying outta my butt?[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  6. kristoffer
    May 21, 2001
    32
    Norway
    ok, that dident sound to hard. what do u think a shop will charge me for the jobb???
    Kristoffer
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Probably somewhere in the ball park of 200-250
