Valve seals
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Jan 14, 2002.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    Nashville Tn
    Ok, I know most of the hype on this question.
    Im replacing the old style with the umbrella type seals. I was reading through the Haynes manual and my "how to rebuild your 350 chevy motor" and they both refer to the umbrella seals. But one says that the umbrealla type seals are MOST often used in conjunction with the flat type seals. Is this true or not for my stock application?
    Also, just to verify, the seals (umbrella style) go on after the retainers not between the umbrella and the retainer, correct?
    So this would be valve, spacer, spring, umbrella, retainer, umbrella seal, then the the lock ring thingy.........
    All I know is the umbrella seals that the guy gave look nothing like the stock seals in the pictures I've seen.
    Still hoping the GOV'T will ban the use of loud stereos with RAP music. [​IMG]
    <a target="_blank" href=http://www.mccords.s5.com/myk5/index.htm>NashvilleK5</a>
