Valve seals
Discussion in '1982-Present GM Diesel' started by Tybee, Jul 23, 2002.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Anybody ever replace them? How hard to replace?
  2. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    Is this for your truck? Don't you have new heads?
  3. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Yes, and the heads are almost a year old. Its the only thing I can think of that could be the cause of my oil consumtion. Im not leaking any and im going through a quart every 25 to 35 miles! /forums/images/icons/shocked.gif
  4. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Holy batman! A quart in 25 to 30 miles? You'd better be doing a compression check. I don't think valve stem seals could be your problem. More likely bad or broken rings.
    Casey
  5. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    when I bought the truck almost 2 years ago it didnt go through oil at all. I replaced the heads and had a valve cover leak, I thought all the oil was leaking from there. After replacing the valve cover and gasket there is now no leak. And I figured the rings wouldnt go bad that fast. I also never noticed a power difference, just a slight one when I put the 35s on. Any other suggestions? Thanks, Troy
