Valve seals
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by River, Aug 25, 2000.
  1. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    Wich are good aftermarket valve seals for a `89 350 TBI engine.
    Both of my cars smoke when starting up or after idling for a while.
    Greetings from Amsterdam.
    River `90 K5, 350, TH700R4, NP241, "33, 3.08, 10 bolt F, 10 Bolt R
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    One thing I've heard is that the old o-ring style seals should be replaced with umbrella-style ones. Not sure why, but that's what everybody has told me..........
  3. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    Thats just the opposite of what I've always done. Anytime I had a set of heads down, I've always paid the extra for "perfect circle" style seals. I've seen the umbrella type crack and come out in pieces. Maybe things have changed or there is a better made umbrella seal. I'm an old guy so I might not be up to speed, but I got a set of used crate moter heads coming and I was planning on doing p.c. seals on 'em. I'm interested in seeing where this thread goes.
    John
    So Much to do, So LITTLE cash.
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Hey, how about some more input on this subject.....I need to replace mine also.........what's the hot setup? I also don't want to pull the heads. Anyone?
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  5. 89Jimmy
    192
    Just movin' it back up. Nobody has any opinions on this?
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    i will seoncd the Umbrella seal motion! I have heard to NOT use the o-ring tye seal and that the Umbrella seals are the way to go.
    Sorry 89 Jimmy, i am not flaming you..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  7. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    That's the same thing I've done on all mine. Current Blazer not included(I'm working on it, just give me time).
    The umbrella style came out in many peices and was VERY brittle. The O-rings seem to last a little longer and hold their pliability (is that a word) and not get brittle.
    Kyle
    89K5
  8. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    I had put umbrella seals in my vette and when it came time for another motor (1year later) I put OEM that had the small spring. Now nothing but smoke when I start them up. Wish I still had the umbrella type. As far as deterioration it has to be composition so I'd just look at different brands. Just thought I'd include a pic of the vette... 12.4sec @109mph in 1/4.....
    Love, Peace, and Hair Grease...........
  9. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    My 90 Blazer was smoking on start up when I bought it. I just bought the valve seals from the GM dealer, the replacement seals were $49.95. I replaced them with the heads on. Just use the air pressure trick in the cylinders and a valve spring tool designed to use with the heads still on and it is a fairly easy job. My Blazer has not smoked a bit since I did this about a year ago.
  10. Michael
    1,576
    Sherman, Texas
  11. scrapper
    scrapper Registered Member
    Jun 12, 2000
    33
    Wisconsin
    My 85 smokes from the valve seals,so I asked a engine bulider what he suggested as far as seals.The answer that I got was dependant on the heads.If the heads are stock and have not had any valve work,(guides installed) you should install the umbrella style seals.These will allow oil to go past them and lube the guides.If the heads are machined and have guides installed then they should use the o-ring style.These do not allow any oil past them for luberication of tyhe guides.As I do not want to take my heads off,I am going to go the umbrella route.This will be this comming weekends project.
  12. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    The only caution with using umbrella type seals is high lift cam applications (.500 or greater). It will eventually crush the seals. Victor makes a seal that locks to the valve guide and has teflon in them that work pretty good. Stock cams or RV type cams (I'm running a Comp Cams Extreme Energy)will keep the lift down and increases the duration.
    One other thing. If the valve guides are worn, don't waste your time and money having them knurled. Knurling the guides only displaces metal and you will be paying the machinist to have them redone in a short time. Have new guides installed. If you can, use bronze guides. They will last longer than steel guides.
