valve stem cap problems - help ASAP
Discussion in 'The Garage' started by 84gmcjimmy, Apr 12, 2006.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I have 4 aluminum wheels and 4 32" all terrain tires mounted on the Jimmy. I want to take them off and put them on the toyota for this weekend. I can't get any of the FOUR valve stem caps off. They are a different kind than normal, instead of a cap with grips on, they have a hex sort of shape (not sure if it has 6 points or not) so I can't get it off. I think its seized. I gripped the valve rubber part with pliers and tried twisting the cap off and it won't come off.
    Any ideas on how to take it off? Thanks
  2. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    try harder
  3. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    :haha: lmfao
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    No seriously, I dont want to wreck the valve stem so I can't try harder.
    Someone please give me good help:doah:
  5. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I agree with Masiony. Put a pair of pliers on the valve stem and a pair on the cap and try it that way. Why do you need to get the valve stem cap off just to put the tires on your 'Yota? Is it just to air them down?
    Rick
    PS: try spraying them down with some PB Blaster.
  6. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    if it is the same chrome hex ones ive seen, just run a socket on it. if it spins the valve stem, then put a pair of vise grips at the base to keep it still. but seriously, all this fuss for a vavle stem? they are like a buck a piece. just man-handle that thing.
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    steve, if twisting the cap off ruins the stem, the stems were rotten and in need of replacement anyway.
  8. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ROTFLMFAO!!!:haha: :haha:
  9. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Um keep twisting to the left....
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Sorry, to clarify my first post...
    One tire is completely flat, so i NEED it off. The rest I just want to get off so in the future when I NEED to air down/fill up I can get them off.
    They are the "chrome" ones your talking about, but they are pink (previous owner) and I will try a socket on there.
    Are valve stems universal, or do I need a certain kind for a certain rim?
    I will try harder I guess. Thanks guys
  11. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    there are two different sizes for the hole in the rim. other than that, they are universal.
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Thanks. Should I get new ones? I ripped up the rubber, its almost all off. Just the stem tube is showing. I got the cap off though, it was corroded on.
  13. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    You should go ahead and replace all of them. I started using the metal chrome ones that screw together with a nut on each side of the rim. As far as the types of valve stems, 95% of them are the smaller valve stem. The bigger ones that I've seen are usually on farm implement type tires. :D
    Also, if the base and stem are rubber, if you can get the bead broke loose from the rim you can use a razor blade to cut the base off and it should fall right out.
    Rick
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Thanks I will HOPE to pick new valve stems up tonight. Do I need anything else, special tools?
  15. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    If you get the rubber ones, just use a pair of pliers to pull them up through the rim. Just be careful not to tear them up. If you buy the metal ones just use a couple of wrenches. Just make sure not to over tighten them. :D
    Rick
    Oh yeah, a little bit of soapy water lets them go in a lot easier.
  16. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    my 15x10 steels had the larger hole. they are nothing special as far as rims go. and walmart had the valve stems for 1.88 for a pair. if you use rubber ones, spray a little paint on the hole before you try and put it in. it will lube it up a little while the paint is still wet. then when the paint dries it will help seal it. just the plier method mentioned above. if you do it right, it goes right in without a struggle.
  17. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Hey steve. Got any progress pics on the jimmy? Last I checked in you had just taken it off the frame, then winter set in. So it's been about a year or so... lol.
  18. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    The blazer got scrapped. Not enough money or time for that and my Jimmy. Kind of regret scrapping it, I wish I could have sold it for a bit more money. Oh well it was fun while it lasted...
  19. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    So you have/had a blazer and a jimmy?
  20. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Also if you have a metal cap for the valve stem, thread that on there and grip the metal cap with the pliers instead of the valve stem. This will keep you from chewing up the rubber part when you pull them through.
