valve-timeing, with a Twizt
Discussion in 'The Garage' started by Twiz, Mar 25, 2002.
  1. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    The miller cycle engine. (Mazda)
    Small 6-cyl, 4-valves per cyl. With a little huffer and dual intercoolers. Pretty standerd stuff, right?
    The funky part is the valve timeing. The intake valve is held open far-into the compression stroke. Basicaly, cutting the compression stroke in half. This also cuts the pumping losses in half, as the piston does not have to compress an "Over-Filled" cyl of air. (and therefore, increases efficiency)
    As the piston is on the up-swing on the compression stroke, normaly, the freash charge in the cyl would end up-being pumped back out, into the intake manifold. But, the blower keeps the flow neutrilized at the valve. *I assume*, -This is where I kinda loose it, I'm not sure where the "flow" is, if any. And how much is being compresed. But thats kinda of irrelivent*-.
    The spark ignites the A/F mix, and forces the piston down the bore. Now this is the fun part, The piston has a full-range of motion on the power stroke, so the engine can extract every ounce of power avalibe.
    So, the Miller cycle engine has:
    - The efficency of a smaller displacement engine. (Higher fuel economy)
    - The power of a larger displacement engine. (Higher-out-put, due to the extended power stroke)
    I didn't know where else to post this. Another thread, got me thinking about "funky" valve timeing, and I didn't want to swipe that thread.
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    <a target="_blank" href=http://www.tokyo-gas.co.jp/techno/eti/ene99/english/09e.html>http://www.tokyo-gas.co.jp/techno/eti/ene99/english/09e.html</a>
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    You want to convert that to english for me?
    I'm not an engieer, just a regular ol' gear-head, that likes to talk-shop. /forums/images/icons/smile.gif
