Van 10bolt axles?
Discussion in 'The Garage' started by jjlaughner, Feb 18, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Are they wider than truck 10bolts? Do they use the same truck gears? Could I swap my gears/diff over to a van axle if it is wider?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes wider and yes same diff and carrier units and design, and same as car too, all 8.5" 10 bolt, and in fornt of K10 and K20 trucks too, 8.5" gm corp is 8.5" gm corp except for a few certain uncommon 60s 70s ones that had bearings pressed to axle shafts, in bigger cars certain models years called the B&O type axle
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Hey guy, I think sometime in the near future we might be making a run up your way... can you find me a 10bolt van axle /forums/images/graemlins/wink.gif
