Van 14 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87GMC, Mar 13, 2002.
  1. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    What years did the vans have 14 bolts? Are they in 3/4 ton and 1 ton? Are the perches the same as the 3/4 ton and 1 ton truck axles--1 ton being farther in than the 3/4 ton?Anyone selling one?
  2. steve_97
    steve_97 Registered Member
    Feb 27, 2002
    25
    Boise, Idaho
    Im not sure on all the years or models available, but i used an 14 FF from a `76 1 ton van, in my 73 k5. the shock mounts and spring pads both had to be relocated. The axle i used had spring mounts that were wider than mine. But so was the axle so it was worth it to me.
  3. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Yes a 14 off a van will work better then a one ton. The axil is the right lenght, but you will have relocate some stuff. I know a quy that is doing this.
