Van 14b FF..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big pappa b, Feb 19, 2003.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Just curious if anyone is using them and if the extra length of the housing is giving u any problems?
    thanks
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    I have one in my truck from a "P" series van, it's roughly the same width as my front end. I love it, it's never caused me any trouble.
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I havent had any problems with mine.
  4. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I have one from a 1978 G30 GMC van.
    I like the look of the extra width.
  5. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    I cant wait until I get mine installed I just bought one myself WOOOHOO
  6. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I too was thinking about getting one of those.
    I have a question though. Do they bolt right in or is some welding involved to move pads or anything else?
  7. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    I had to move both the pads and shock mounts on mine.
  8. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Yep, pads and shock mounts......really very easy though.
  9. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Has any of you experienced problems with the brake system after doing this and what did you do with the parking brake? /forums/images/graemlins/ears.gif
  10. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Just my 2 cents Im gonna go disks its not to expensive and you might as well do it while you got them off.
  11. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    Cave,
    Where did you get yours? Guess I can keep mine then huh.....
    Doc
  12. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Just did the same disc brake swap.
    Dont run an e-brake yet....trying to fab up my own t-case e-brake.
  13. Strahan
    Strahan 1/2 ton status
    Dec 4, 2001
    251
    Yoe, PA
    Sweet. So this would eliminate the tucked in rear tire effect w/o having to use spacers then? That's the one thing I hate about my truck. The front tires come flush to the sides of the truck but the rears are an inch or so recessed. Irritates the hell outta me /forums/images/graemlins/smile.gif
  14. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yes a van rear fixes that.
  15. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The only thing you have to remember to check is if you have enough clearance to stuff the tires up.
    The way it is stock the tires stuff inside the wheel well.
    If you hacked enough or have enough lift where you don't have that problem, then go ahead, you also get a better track which is more stable.
    /forums/images/graemlins/thumb.gif
  16. Lazydog
    Lazydog 1/2 ton status
    Apr 17, 2002
    129
    Phoenix, Arizona
    I called a guy who has a van to part out. He measured the rear he says has a 14 bolt FF rear. It measured at 56". Thats the same width as the 12 bolt I have in my Jimmy now. The front D44 in my truck measured 61". Is there more than one width of 14 bolt FF in vans? I was thinking that the guy was confused about the type of axle he has. Let me know. Thanks
  17. Strahan
    Dec 4, 2001
    251
    Yoe, PA
    What years did the vans have that 14ff?
