Van axles vs. wheel spacers
Discussion in 'The Garage' started by toy4fun, Jun 23, 2003.
  1. toy4fun
    toy4fun 1/2 ton status
    Sep 10, 2002
    220
    Helper, UT.
    I was wondering the advantges/disadvantages of running a Van 14FF. vs. a Truck 14FF. with wheel spacers /forums/images/graemlins/thinking.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    van axle will make your width the same as the front, making spacers unneeded
  3. toy4fun
    Sep 10, 2002
    220
    Helper, UT.
    Are the van axles hard (expensive) to get a hold of /forums/images/graemlins/rolleyes.gif If I should brake one /forums/images/graemlins/grin.gif
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    A van axle will be easier on your wheel bearings than spacers would be. Spacers or small back space rims = extra leverage on the wheel bearings. /forums/images/graemlins/thumb.gif
  5. Priest
    Priest Registered Member
    Apr 22, 2002
    95
    Tracy, CA
    My .02 for what it's worth.
    (I will now make the disclaimer that I am a Toyota guy and ocassionaly visit this board just for the hell of it)
    There is nothing wrong with running a reasonable spacer. Pretty much all of the guys that have done an SAS on a toy (myself included) run 3/4" spacers on the front. Some guys are now running 1.5" spacers without any problems. Bruce is right, they do create more leverage on the bearings but were talking about a 14bolt here. I don't think that added bit of leverage is going to make any difference on the life span of those bearings.
    Given the difficulty that can be had finding a van housing I would just run a spacer.
  6. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Depends... if you're a trail, mud, sand, small rock guy, spacers will definately be fine. IF you're hardcore into rock crawling, the added leverage will definately catch up to you.
  7. toy4fun
    Sep 10, 2002
    220
    Helper, UT.
    I'm a Toyota guy also! Lift and Lock what could be simpler? Ay I know my toy (FJ40) does not put enough HP to break any thing (with the exception of an birfield or my wallet)
    Is it worth changing? I have a Truck 14FF and spacers, I can pick a Van 14FF for around $150. None of which is under the truck right now,
  8. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I had heard that the van 14ff's actually used a smaller axle, might be something else to check into....
  9. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    Around here van 14b's are more plentiful, but it may be different where you are at. It's probably easier to find an aftermarket axle for a truck 14b.
  10. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    Smaller axle? I have a 14FF off a van and the Detroit Locker was the same as for any other 14FF.
  11. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    another thing to think about, most of us have 1/2 ton trucks...a 14FF is a 1 ton axle, so whats 1"inch going to do to a one ton axle on a lighter truck...I know a toy guy running 2-1/2" spacers...
    I'm running the Echobit 8 to 6 lug spacers at 1" inch each side...
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    what do the spacers run? just curious
  13. TONYP
    Aug 13, 2002
    2,116
    so cal
    these are around $130.00 shipped
  14. Priest
    Apr 22, 2002
    95
    Tracy, CA
  15. Priest
    Apr 22, 2002
    95
    Tracy, CA
    I'm running 3/4" spacers but I also have custom 2.5" back spaced wheels so that puts me at around 2" from the stock location. I know of guys running 1.5" spacers with 2" back spaced wheels on toys with out issues (and that's with 38.5" SX's) ... and keep in mind that this is on the front where you have the additional complication of steering where as with at 14bolt we are talking about the rear.
    Again, I say run them.
  16. TONYP
    Aug 13, 2002
    2,116
    so cal
    are those spacers around $130.00 each so two would be $260.00 total...
    Echobit
