van dually 14 bolt FF measurements i found out tonight
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Nov 21, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    measured on an '82 1 ton chassis-cab 12 foot dually cube van(CG31603) and got:
    50" spring pack to spring pack centers and 71" WMS to WMS
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Weird.... Should be a Dana 60 or 70 /forums/images/graemlins/confused.gif
    14-bolt in that wide track width didn't come until 92 or so.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i cant explain it either, but the van is right here in my driveway im working on it, wish i had a digicam!
    anytihng else anyone want to know from the truck ?
  4. u2slow
    May 9, 2001
    2,217
    BC Canada
    The rear end has probably been swapped... Vans are essentially the same from whenever they started until 96 - so it is possible.
    I bet the center section has reinforcing ribs all over it. The older ones were basically smooth.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its one of those vans that the frame rails and body and everything was chopped off at just behind seats and an entire cube box was attached ot the van front third of body, it has no factory frame rails after behind the seats, has a one piece channel stamped steel body tub, is really wide, even says such on the SPID label under the hood, i cant see how any narrower of an axle could work under the truck, it just couldnt, you see these cube vans all the time riding around.
    thanks
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    This is a step van or cube van, they came with wider axles than regular vans.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
