Vapor Canister Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stump_puller, Sep 6, 2003.
  1. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    I am currently putting my truck back together and I need to know if I can elimnate the vapor canister. The only hose currently goin to it is the one that seems to go back to the gas tank. Can I just plug it off or what? /forums/images/graemlins/1zhelp.gif
    Thanks in advance,
    Don
    /forums/images/graemlins/truck.gif
    P.S. By the way it is a '85 with a 350, performer rpm intake and an edlebrock 600cfm carb
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The other hose goes to vaccuum on the carb. If you don't have emissions tests then you can just leave everything how it is. </font>
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I removed mine, I'm gonna put a breather on the end of the gas tank line and it should be fine. My buddy kept going on about how I should remove it, that thing weighs like 5 pounds! I was like alright, pulled it out, it weighs like 1.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Whatever you do, make sure you don't plug off the line that goes to the tank.
    The vapor cannister is there for a reason. It allows your gas tank to "breathe" when the gas warms up throughout the day and starts to produce fumes. Fumes = pressure and when that pressure starts to build it needs somewhere to go. That's why most people run a vented gas cap, too.
    If you eliminate the vapor cannister, just make sure that the pressure is still able to get out of your gas tank.
  5. stump_puller
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    Thanks, so I'll just extended the line up higher next to my axle breather hoses and put a small breather on it. Thanks everyone /forums/images/graemlins/thumb.gif.
    Don
  6. dyeager535
    26,981
    Only problem I have with the breather is condensation in the tank.
    I can't remember, do the gas caps allow air in, but not out, until internal tank pressure reaches the caps pressure rating?
    Was thinking of using an axle breather myself, but since I don't plan on taking this tank back down for 100,000 miles, I don't want water building up in there.
