vapour recycle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by razorblade, Jan 14, 2003.
  1. razorblade
    razorblade Registered Member
    Jan 8, 2003
    6
    italy-monza
    hi!
    i have an important question...
    i think i have a problem about the canister for vapour recycle...
    there is a tube which breathe in fuel not vapour of fuel...
    is it normal?!
    i don't think so
    thanks
    fabio
  2. dyeager535
    26,975
    The vapor cannister IS hooked up to the fuel tank, but you are correct, it should not be sucking in raw fuel. You *might* get some accumulation, but I don't think even thats normal.
    Perhaps the charcoal filter at the base of the cannister is plugged, forming suction on the cannister purge line. I know in most applications that filter can be changed, you might want to check it out.
