vehicle speed sensor Q?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by foxman, Nov 12, 2001.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    Detroit MI
    While playing around with a scanner tool (on my 90 K5 350 fi), I came up momentarily with a vehicle speed sensor code that said that it short curcited. the idle began to rev high and then went back to normal. I cleared all the codes and it hasn't acted up since. I think that this might be contributing to my delayed/irratic shifts. Has anyone had one of these go bad? Where are they? Can you get the new speed sensor at any normal auto parts store? Thanks for reading and for all the help!!!
  2. dyeager535
    I was reading something the other day that said 90(?) was the first year of electonic GM speedos in trucks. Also mentioned the VSS drives those speedos. I believe that the VSS on yours is on the transmission or transfercase, where a speedometer cable would normally be.
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
