Vehicle won't start, fuel problem
Discussion in 'The Garage' started by jared_leonard, Mar 2, 2006.
  1. jared_leonard
    jared_leonard Newbie
    Mar 2, 2006
    Rocky Mountains, CO
    The other day, upon arriving home, my 1989 K5 Silverado Blazer started to "sputter". I wasn't getting full power from my throttle when I accelerated, but it was very sparatic and the problem seemed to go away. However, the next day my vehicle won't start. If I spray starter fluid directly into the carb, it will start briefly, but stall as soon as it burns through the small amount of started fluid. This leads me to believe that I have fuel delivery problem. I have purchased a new filter, and have not installed it yet due to reluctance to mess with the slightly corroded fuel line. I know it may be the pump, but it's in the tank and I don't want to drain/remove it if I don't have to. Any suggestions? Thanks in advance for your help.
    :confused:
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    89 - is the computer tossing any fault codes?
  3. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    check for spark
    check for ses codes
    check for 2 sec. fuel pump hum when key is first turned on
    check for fuel coming out of injectors when cranking
    if all checks out hold foot to floor and try to start truck, if it starts look at idle air control valve
    also could be coolant temp sensor. (look for ses code for this one)
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    My 88 had a similar problem a couple years ago.
    Turned out to be the fuel filter on the frame rail was plugged.
    Simple to change. Also, as mentioned, check for codes. I think mine had something like a code 43 set. Does sound like fuel problem
  5. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,548
    16
    Anchorage, AK
    I had a similar peoblem with my '90 burb. After replacing the fuel pump and filter, I was advised on this board to change the ignition module. I replaced it and it's been running great ever since.
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    First thing you should do is check for trouble codes. http://www.troublecodes.net/GM/
    Then Beings you have it .Change your fuel filter. It is an easy job. Should change at least every 10 K to keep your pump healthy.
    If the problem is still there and there are no trouble codes
    I would suspect the ignition module.
