Velvet Ride shackels
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tori89k5, Apr 12, 2001.
  1. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Hey, anyone out here have any experience with the "Velvet Ride" rear shackles that you can get aftermarket, like at NAPA. They are a rubber mounted shackle of some sort. Let me know if any of you have any experience with these. They cost about $140 for a set. Hate to waste the $ if they suck....
    Bone stock '89 K5..... so far anyway....
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Drop a private message to AZBLAZER, Doug had them on his '79 K5, said they made a big difference on both articulation and ride quality. That is the way I am going, instead of a shackle flip I am going 4" rear springs with the Velvet Rides.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  3. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I have some I got from Blazen91 and put on my 3/4 ton pull vehicle. All I can say is WOW they completely took out that bone jarring jolt I used to have when hitting a pot hole. I give them two thumbs up.
    I thought I was wrong once,
    but I was mistaken
  4. Butch
    Apr 26, 2000
    1,338
    Austin, TX
    I have some I got from Blazen91 and put on my 3/4 ton pull vehicle. All I can say is WOW they completely took out that bone jarring jolt I used to have when hitting a pot hole. I give them two thumbs up. Only thing is they are longer than my originals and it did squat the rear about 3/4".
    but I was mistaken
  5. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    What is the diff. between ORD's and Velvet Ride? Not to familiar with the Velvet Ride. Pros and cons?? Why would I want one vs. the other?
  6. timebomb1602
    timebomb1602 1/2 ton status
    Mar 30, 2001
    138
    hudsonville, MI
    If anyone wants to see them they are at <A target="_blank" HREF=http://www.velvet-ride.com>http://www.velvet-ride.com</A> I don't know about losing almost an inch of lift though..
    <font color=red>1991 GMC Jimmy 350tbi 3.42</font color=red>[​IMG]
  7. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    You know, my plans I think are the following... BDS 5 1/2" on rear with velvet shackles, front BDS 4" with ORD's front shackles... All in all is should leave about 1/4" higher in the rear...
    Does this sound practical and managable?
    <font color=blue> Jeff </font color=blue>
    [​IMG][​IMG]
  8. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    The ORD looks like a stock shackle installed upside down. It is designed to lift your truck. The Velvet is like a stock shackle with rubber parts to cushion rough rides. It's not designed to lift the truck and you cannot flip it.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    That is true, the velvet ride's eliminate the possibility of a flip. I spoke with their tech supt yesterday to see if they made a compression model (normal Chevy is tension) which could be used. The answer was no. Also, depending on the weight of the vehicle, it can actually lower the back by 3/4 (at best) to 3"(!!!!!). Frankly, I think that is bad design. If they know this, why not design it to be a drop in replacement without changing the ride height? So, you gotta buy a lift with more arch == stiffer springs so that you can install a shackle that is supposed to soften the ride?
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  10. BurbinOR
    5,829
    Oregon
    We might want to get the input of someone who really knows - and ran them. AZBLAZER, are you out there..............? Doug ran them for 2 years and loved them, and never said a word about a saggy rear end with these shackles. I know what the website said about the 3" rearend drop on some models, but let's hope Doug can give his real-world input.
  11. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    ok AZBLAZER, info would be greatly appreciated...
    [​IMG][​IMG]
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I don't know for sure since, as you point out, I have never run them. However, their own tech guy told me that most trucks will drop "at least 3/4 inch" and that Subs or trucks with campers often drop 2-3". Obviously someone who has run them would be ideal to talk to but when the people making and selling them admit openly to a serious problem, I tend to believe it. What I don't believe is when people start with "it's perfect" lines. I’m also looking forward to what AZBlazer has to say since they might be nice on my Ram even though I can’t run them on my K30 (eventually to have a flip).
    Bad Dog
  13. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea... well it kind of sounds like if you're not doing any towing or anything to load the springs much then they would be great... which actually will probably count me out unless I buy a truck to restore too... [​IMG] (future project after my K5) [​IMG]
    [​IMG][​IMG]
  14. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    When they were on the Blazer before selling them to BUTCH, I had about an inch of saggy butt!! You could get a ORD 1" add-a-leaf and fix that. I didn't notice much of a ride difference after taking them out. With such a short wheel base, I think they will always ride like a truck. Over all I had no complants about the product. I just didn't want the saggy butt(this was before the 1" add-a-leaf came out) and plan on a shackle flip.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  15. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I run the velvet rides on my 83 1 ton. I lost about 1/2" of lift when I installed them. The height loss is due to the shackle design. I'm not sure that it would be possible to make the shackle any shorter. I've had this setup for almost a year and there has not been any change in height. I stuff over 4,000 LBS in the bed on a fairly regular basis and the shackles have not had any negative effect to hauling or to trailering 8,500Lbs. On the plus side they make driving this truck everyday feasable. The tail no longer hops over washboards and it really smoothed out other road bumps. I would recomend them to anyone with a HD suspension. I'm not sure it would be worthwhile on a 1/2 ton.
  16. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    Hey thanks for the info...
    Now the tuff question, would it be worth going to a taller rear leaf spring to be able to run the velvet shackle?
    [​IMG][​IMG]
  17. prjt_blzr
    Mar 4, 2001
    352
    COS, CO
    This is going to be a personal preference issue. I've not installed the velvet rides on my wife's Blazer because I don't think that it rides poorly. They would probably help on washboards alot and some on the rest. Is it worth $150 but the spring changes?????/
  18. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    Well, living in Wyoming and I drive a LOT of dirt roads with wash boards... Maybe I'll do the shackle flip first, and if I don't like it then I'll do and add a leaf w/ the velvet ride's...
    I'm not concerned about the $150.00 if it rides like I want it too, but first things first. That would be a luxury I think...
    [​IMG][​IMG]
  19. prjt_blzr
    Mar 4, 2001
    352
    COS, CO
    Good Luck on your project. I hope that things work out for ya.
    Mike
  20. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Just keep your old spring mounts when you do the flip. You will have to put the stock ones back on (or make/find some like them) before you put the velvet rides on. I'm sure you know that but just wanted to throw that in to make sure for future reference. Good luck.
    Bad Dog
