Vent fitting on top of Dana 60 housing
Discussion in 'The Garage' started by pomai, Mar 14, 2005.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Does anybody know were I can get the vent fitting (for lack of the proper name) that goes on the top of the dana 60 housing?
    Also the Dana 60 dust shieds. Thanks Ed
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I was told that people tap the hole and put a brass fitting in there.. I have the same delema... no fitting :p:
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yep, that's your best bet. easy to do. 1/8" pipe thread tap, 1$ fitting, and your on your way.
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Make sure you have the diff cover off and you catch all the shavings in a rag or something before you tap it. Mie keep breaking off cause my ram keeps hitting the fitting. I may plug it and drill another hole somewhere else.:crazy:
  5. pomai
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Good idea, Thanks alot, Ed
  6. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    are u runnig hi-steer?
    pompai i did the same 1/8" npt fitting they are talking about.
  7. garydan
    garydan 1/2 ton status
    Jun 9, 2009
    659
    Port Saint Lucie, Fl.
    Figured I'd bring a post back from the dead here. I need a fitting for the Dana 60 I have. I took my 10-bolt axle off the front and it has a bent metal fitting coming off of it. Can I use that fitting? If I can, I'm not sure how to get it off of the 10-bolt. I tried yanking on it, and it won't thread loose because the bend hits the housing...
    Is there somewhere you can buy these?
  8. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    its pressed in, just get something under it and pry it out. pull on it harder i guess.
  9. garydan
    Jun 9, 2009
    659
    Ok, I'll man up and get it out :D
    Will I be able to use it in the Dana 60?
  10. KohlTrain
    KohlTrain Registered Member Premium Member
    Aug 8, 2005
    89
    Ione, Ca
    This is what I did. Get a 1/8npt to barb fitting slap hose on with hose clamp.
  11. garydan
    Jun 9, 2009
    659
    Ok, do you still have to tap the hole? Should I be able to find one of those fittings at home depot? Or a auto-parts store?
  12. toomany
    toomany 1/2 ton status Premium Member
    Aug 25, 2008
    1,972
    77
    Auburn, MI
    If you removed a pressed in fitting, then you will have to tap the hole. You should be able to find a tap and fitting at Home Depot or a good auto store.
    It's been my experiance that once the pressed fittings are removed, you can't get them to stay back in.
  13. garydan
    Jun 9, 2009
    659
    Yeah well I won't have to worry about that now. I busted the fitting on the 10-bolt. So I'll be looking for the tap and fitting at home depot.
  14. Yobtaf
    Yobtaf 1/2 ton status GMOTM Winner
    Sep 4, 2006
    2,841
    West Ham United! ®
    I took one off then put a screw driver on the flat lip and got it back in, put a little silicone around it, and that was it.
  15. owenst7
    owenst7 1/2 ton status
    Feb 12, 2008
    1,450
    Anchorage and Reno
    It takes about 45 seconds to spin a 1/8" (I think thats what it was) NPT tap in there to cut some threads. The hole is already the correct size for a standard NPT barb fitting that you can get off the brass fitting rack at Homo Depot, or just about anywhere else. I'm almost positive its the same size that sending units are. Most people already have those taps in their toolbox.
    I used windshield sprayer EPDM hose cuz it's really cheap and the correct ID for weed-whacker fuel filters that I can buy in bulk. The filters are really small and cheap, so they work well for breathers.
  16. garydan
    Jun 9, 2009
    659
    The hole I have is actually 11/32 wide.
  17. owenst7
    Feb 12, 2008
    1,450
    Anchorage and Reno
    That's the proper diameter for the tap.
