Vent hole on my th350?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jaden, Apr 5, 2002.
  1. Jaden
    Jaden Registered Member
    Jan 25, 2001
    61
    Truck is now spewing tranny fluid out around the fill tube after I shut the truck off I have been told that it can be caused by the vent hole possibly being clogged. Any ideas greatly help as I cannot keep fluid in this thing.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    This is something you need to take care of soon!
    http://coloradok5.com/blazerfest2.shtml About half way down is a pic of my truck...same thing happened (I also had some water in the tranny). The breather is on the driver side twards the top. It is just a little L-shaped tube that points down.
    Also...Are you running a tranny cooler? If not you should. I have a B&M...the stacked plate type are the best (like B&M).
  3. Jaden
    Jan 25, 2001
    61
    I am running a tranny cooler so I am taken care of there. Also the fluid coming out looks perfect no burning and no contaminants so I think once I get this resolved it will be good to go.
  4. BANKO
    BANKO Registered Member
    Nov 21, 2001
    18
    Sunnyvale, CA
    This is a real pain in the butt. I had this happen on my Chevelle when I swapped a tranny out of another vehicle that had been sitting for a long while. In my case a mud wasp found a home in the vent tube. I noticed the issue when the tranny would build up pressure and spew fluid out of the filler tube. The obivious remedy is to unclog the vent tube on the passenger's side. The best way would be to remove the tube but this can be challenging when the tranny is installed in a vehicle. I used a thin copper rod to unclog the vent tube and then followed up with using compressed air to blow out the remaining material. After this was done, I never again had the issue occur. I hope this helps.
    -Josh
  5. BANKO
    Nov 21, 2001
    18
    Sunnyvale, CA
    -Josh
  6. BANKO
    Nov 21, 2001
    18
    Sunnyvale, CA
    -Josh
  7. Jaden
    Jan 25, 2001
    61
    Ok now I am confused is the vent on the drivers side or the passenger side? I found a small hole at the top of my tranny driver side but it looks like it is just a hole there is no tube or anything on it? HELP!!!
