Vent Tube Broke Off
Discussion in 'The Garage' started by big jimmy 91, Nov 2, 2004.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    The vent tube broke off the rear diff. in my friends 85 chev 4X4 /forums/images/graemlins/angryfire.gif
    It sheared off flush with the diff.
    How does a guy repair this problem as it is no good to leave it open for water to get in.
    How are these things put in the diff.? /forums/images/graemlins/ears.gif
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    rust must have gotten the best of it. I think they are originally pressed in. But either way, the cheapest easiest fix is gonna be to insert a tube of a smaller diameter, and seal the fitment with RTV. It only needs to breath a little, not flow, so you should be fine.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Drill it out and thread it to 1/4 NPT
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    When I get around to it , I am tapping my project truck for a 1/4 inch fitting with threads on top , and I have 120 inch stainlees hoses ( icemaker connect to home ) at my work to run . they are rated continously for over 125 psi , so they should last forever on here . And I am also tapping the cage for this so it will run from axle to cage /forums/images/graemlins/thumb.gif
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    in the 14ff the hole is already the right size for a 1/4 NPT tap, on the 60, (and on the 1/2 stuff to it think)the hole is smaller i used a 3/8 NC tap and a barb fitting. diddent have to drill eaither housing. some people will say not to use a regular( non NPT) fittin, but i was happy with it and no leaks at all. so this is what i would recomend
  6. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    That Happened to me. I took a screw extractor and got the rest of the old piece out. drilled & tapped out for an air hose fitting and hooked up a coiled air hose to it. /forums/images/graemlins/thumb.gif
