Vent Tube on a 700r4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbluethunder, Oct 12, 2002.
  1. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    where is it...anyone got a pic. i spent half an hour today up underneath the truck trying to find the darn thing with no luck.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    On top of the tranny, about 1 inch right of the centerline, about 9 inches back from the front edge of the bellhousing. It's almost straight above the cooling line connections on the right side. /forums/images/graemlins/cool.gif
  3. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    cool...thanks
  4. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    ok, so i found the vent tube....and it broke off in my hands...(fawking plastic piece of $hit). is this something that i can just pull the rest of the plastic out and replace or is it pushed in from the inside and i need to do some serious work to replace it.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    It pulls out from the outside. Yes, they are cheap and do little more than control the direction of the oil spray if you vent it. I would say pull the rest of it out and put a better one in. I would like to see it go up higher on the vehicle for a vent, but make sure that it is located so that the ATF goes somewhere safe if it squirts. You especially don't want it on hot exhaust components.
    I have been meaning to run my Tcase, Tranny and diff vents up to the top of the engine compartment sometime. Maybe if you mess with the tranny vent, now would be a good time to do all 4?
  6. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    thats actually what i'm doing...i ran one from teh rear axle to the front, t'd it to the front axle and then up to the firewall where it attaches to a cheap little fuel filter. i'm running the t-case and going to t my transmission in to it and then run that to the firewall with the fuel filter. of course everything vent tube is metal except the one that's a pain in the a$$ to get to.
