Vent Tubes
Discussion in 'The Garage' started by nau81blazer, Feb 5, 2005.
  1. nau81blazer
    nau81blazer 1/2 ton status
    Mar 6, 2004
    329
    Cincinnati, OH
    Hey everyone,
    I was wondering if it matters how long you make your vent tubes? Do they require some sort of specific length or can I run them as high as I want? Thanks for the info.
    --Adam
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    As long as they can breathe, run 'em as high as you want. When the time comes I'll be runnin all of mien to the firewall. I did that to my last truck and put on some cheapie clear plastic fuel filters, worked awesome.
  3. nau81blazer
    Mar 6, 2004
    329
    Cincinnati, OH
    Cool, thanks for the info.
    --Adam
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Run them as high as you can get them if you do any water crossings or things of that nature. Last weekend I was in about 3 feet of water crossing the Agua Fria and luckily my vents were high enough. I checked both the tcase and rear diff this weekend and they were water free. I still need to check the front diff though.
    Harley
  5. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    run them as high as you plan to ford the rig, as high aas your air intake goes.
  6. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Vent Tubes on the axles
    Hello,
    Where are the Vent Tubes located?
    Adam
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    located top side of everything, top of trans, top of case, top of axle diffs- or on an axle tube top side, sometimes its just a hole in the case, sometimes a short stubby valve with loose cap on it, and sometimes a black rubber hose and all, or a short tube of white nylon tube, it varies over the years for different components
  8. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    I have pulled the 700 a couple times and never seen one. Probably because i wasn't looking.... do you know if the 700r4 have one?
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    As high as you can , if you have a cage , vent then into that and have a hole at the highest point .
    For the front get rid of the connection on the front crossmember where it joins two hoses and run one long one :)
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    It's on the top of the case about midway back the trans. Usually a little tiny plastic tube or if your lucky a metal tube. The plastic ones usually break off.
    On a side note if you ever rebuild a trans or buy a rebuilt have them tap the hole for a pipe fitting then you can put a decent hose on it. There is plenty of room for tapping there so dont let them talk ya out of it for that reason.
    Another simple thing to help with keeping water out of vent tubes is to make the vent point downward when complete so water has to travel up the tube before going down in to the trans, axle, transfer whatever it is your working with. Basically and upside down "U" with the hose and then put your filter on there still.
