vent window conversion/ topper pin
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big d, Apr 14, 2002.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    does anyone know if you can convert an older model k5 vent window to the newer bush button lock style , without switching out the entire door ? also does anyone know where one can purchase the line up pin on the back drivers side rear that the top has to go in, or do older model k5's have these ? i just helped a friend remove his top on his 91' and was surprised to see this. thanks in advance.
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    LMC sells the pushbutton latches for $20 each. I haven't seen an alignment pin, but I would think a salvage yard would have them if they unbolt...if not looks like one could be fabbed easily enuff.
  3. big d
    Oct 24, 2001
    1,236
    illinois
    thanks man, thats good info. i checked it out. it should work.
