very cheap maby do it you self crossover streeing?
Discussion in 'The Garage' started by screamer*145, Sep 28, 2004.
  1. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    i just looked at this site http://bulletproofsteering.com/steeringsystems.html
    and the way they did a cross over was the stock nuckle between the draglink and the tirod with some high zoot grade 9 space bolt thing? /forums/images/graemlins/whistling.gif it looks like it would work but have never seen before they had to drill out the pass. nuckle for the bolt with the tirod mounted to the botom! now the nut on the bolt dose acepet a coter key. has any one ever tryed this or had expriance with them!
    any ideas or thought will be apriceated! /forums/images/graemlins/thumb.gif
    P.S.- sorry for bad spelling!
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    you'll have to run a spring under, or link suspension to clear the draglink that way. There are a few morons on that have pics of giant "Z" type drag links to work with normal spring over but they are a failure waiting to happen.
  3. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    the thing is that i dont plan on doing the high steer just the crossover and wanted to know what people think about it and would be ok for street use also i dont see any problems if you only do the crossover part! /forums/images/graemlins/thinking.gif
  4. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    That setup will only work for spring under, or coil front suspension...basically if your running a fullside chev product, it won't fly.
  5. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    My crossover is done exactly like this,and it does work,,,
    I have a 2 wheel drive box with the arm clocked front to rear,a straight drag link over to a steering arm on the pass side with a 2" block.
    The truck has 8" of lift.
    And yes it has the drilled out arms with the grade 9 bolts.
  6. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Is that a 2" block between the axle and spring? Does it like like the draglink would clear if it was only 1" like a zero rate?
    Eric M.
  7. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    like I said before i am not going to do the high steer just the crossover. /forums/images/graemlins/whistling.gif anyway! How dose it work on pavment! also what do you mean by the block? /forums/images/graemlins/woot.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That isn't safe in my opinion.
    I'd just do it right, it's really not that expensive.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the images you linked to are not high steer.
    they are just crossover
    perfectly acceptable way to do it if you want to run hiems
    all you are saving is the search for a flattop knuckle
    you would still have to get the taper machined out to perfectly match the bolt
    IMO this is not a 'hand drill in the driveway' operation, but it is only your steering not something important like a subwoofer install
  10. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    /forums/images/graemlins/rotfl.gif
  11. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    What is not safe about it? I don't know a lot about heim joints, are they not as strong as tie or draglink ends? Do they move less (can't get the same angle as with a draglink end)? Just curious.
    Eric M.
    subwoofer .... that's cold /forums/images/graemlins/shame.gif
  12. dirty willy
    dirty willy Registered Member
    Apr 20, 2004
    6
    Ontario Canada
    I second that will not work on a leaf spring front end. That set up is for coil springs. There is other companies that make cross over steering for D44 and D60s /forums/images/graemlins/smile.gif
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    well as the linked images do not use a steering arm but instead go directly to the tierod mount on the knuckle perhaps yours isnt exactly like that one
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm not going to bet my life on a bolt in single shear. If you want to that is your problem.
    That is rolling suicide in my opinion.
    Grade 9? What a joke.
    m j,
    You're losing it man. Driveway drilled or milled in a machine shop, that's still a lot of stress for one bolt.
  15. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    How does this differ from the threaded end of a tie rod? I'm not doubting if it's safe of not, I'd like to know from a structural point, what part makes it dangerous?
    Eric M.
  16. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    What is not safe about it? ...
    IMO... the basic design doesn't look any less safe than any other crossover setup. The “190,000psi tensile strength” probably exceeds that of an OEM tire rod. The only thing that I think is unsafe about one of the previously described setups is using blocks up front (not counting the 1" zero rates). If that's what it takes to run this setup on a leaf sprung live axle Chevy then I would say it is definitely unsafe.
    But as was casually mentioned earlier (in not some many words), this is you steering. Not somewhere I'd look to cut corners.
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    same as above post Tim,
    if done correctly
    it is as safe as the factory crimped together tierod end that uses a single attachment point and is in single shear.
    the bolt isn't going to be the fail point
    it is much greater size then the necked down tierod ball
  18. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    i think he is using the blocks to clear the high steer setup witch is un safe imo but i dont want to do high steer just the crossover and it dose not look like they machine the tirod mount they just drill it out some!
  19. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    damnit you are not getting it, he doesn't have HIGH STEER!!! High steer goes over the springs thats the way it is. Unless you have real thick leaf springs you won't need a block to clear the springs. The problem is simply this, hold on a second I will make an image.
    notice the gay green line I used to demonstrate this. Notice it goes right through a leaf spring? well what am I thinking, if you REALLY want to do this and do it right you will just notch the leaf springs for clearance.
  20. wasted wages
    Dec 3, 2003
    9,194
    Dallas Texas
    The spacer block is between the knuckle and the steering arm on top of the pass side knuckle.
    IMHO the bolt in shear is no less in strength than a stock tie rod end.I have seen more failures on tie rod ends and ball joints (same principle-ball and socket design)than any heim joints.
