Very Confused...?? Now with video!
Discussion in 'The Garage' started by stockk5, Jun 8, 2006.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    Alright when i put my truck into reverse.. and start ideling backwards while turning i get a loud BANGGG coming from my rear end/ujoint pinion area.. I had my brother look at it for me while i drove it in reverse circles and it made the horrible banging noise a lot. I had him jump in and as soon as he put it in reverse.. i watched the rear ujoint basically twist one way. then very quickly back the other almost as if it was spring loaded in some wierd way. This is in a Dana 60 rear w/ detriot 4:56gears, fresh ujoints. I can upload a small video clip tmrow in the daylight if it would help but it puzzles me, it just started about 2days ago, only did it 1 time each day though.
    NOW WITH VIDEO! this is what happens when i put my truck into reverse.... and when back in park it rolls about 3ft. any idea?
    http://www.youtube.com/watch?v=0I2TU1hxA2w
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Yeah, maybe a video would help out,,,,anything "banging" in a truck is not really good, unless it's you in the back seat:p: :doah:
  3. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I wonder if the ring & pinion gear backlash is excesive. You say you have 4:56 gears, this means that the differentail has been worked on at some time, in order to have 4:56's. Where the 4:56 gears installed recently?
  4. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    na i bought this rear end from some guy last year.. and didnt do anything to it, the pinion seal has been leaking for about a month though.
  5. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    haha yeah.. im not sure why i even posted this but i just went out and had my bro throw it from park to reverse a few times in teh driveway.. u cant see much.. but this is simply from going park to reverse while in the driveway..
    http://www.youtube.com/watch?v=oGUuRCBuW3o
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Pull teh diff cover and check it out. Sounds like one of the pinion bearings could be going out
  7. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    i added a video in the daylight
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    You've gotta pull the cover. Only take you a minute. Something that bizzare should be pretty obvious when you get the cover off.
  9. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    I could not get the sound to play. Tried a few of the other videos on there and heard them just fine
  10. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Looks to me like your backlash is way out but I could be wrong. My detroited 14FF gets about 1/4 turn at the pinion with my backlash.
    Ira
  11. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Maybe you broke some teeth off the ring?
  12. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Agreed! That is more than backlash. You are missing some teeth off of the ring, pinion, or both. Have you been doing any burn outs, or full throttle hill climbs latley?
  13. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    well i took the cover off after work.. and the ring and pinion gears both have all there teeth and i couldnt see any chips or anything like that in the pinion gears either. It seems to be something odd with my detroit locker, w/ the differential cover off tranny in neutral it spins freely forward, when i spin it backwards there is a resistance, like the spring in the detriot is catching or sumthing and it will eventually make a loud click/snap and spin.. i assume this was the sound i was hearing when in reverse and turning just amplified w/ the extra force from the truck actually doing it not my hands. How hard is it to fix a detriot? Thanks for any help guys.
