Very dumb carb questions... pics to explain my questions
Discussion in 'The Garage' started by BranndonC, Aug 7, 2005.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok, so think like i know nothing. which is exactaly what i know, so heres my pics and questions, I think i need a carb spacer so that metal arm thingy doesnt hit the intake manifold, but i'm not sure.
    **********CLICK TO ENLARGE EACH PICTURE**********
  2. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    The really big fitting is fuel intake. Yes the bottom one is adjustment, there is one on each side on the front. That is an electric choke. Gas cable goes on top. Kickdown cable goes on bottom. Looks like you have a carb adapter plate already on there. You will need to get a diagram of all the vacuum hookups. I don't really know what to tell you. Sorry, tried to help.
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    you helped. i have a gasket, but no plate, just the carb and gasket. anyone else ? Thanks for all your information :bow: :bow:
  4. Brocky
    May 22, 2005
    1,170
    I had to put a spacer on mine for my edelbrock 600. Same problem arm was bringing up. I just taught there was a adapter plate on yours. So yes get an a carb spacer.
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    can i pick one up at pep boys or is it an ebay kinda part?
  7. Brocky
    May 22, 2005
    1,170
    NAPA, any parts store. Like $20.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the port on the radiator is another place the 3/4(the bigger) hgeater core hose can go, instead of from water pump port
    some models used the radiator instead of the water pump i cant explain why, maybe someone else can
  9. dyeager535
    26,975
    The two circled screws in first pic do entirely different things.
    Screw on left is one of two idle mix screws, one on the right is the idle speed screw.
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Don't cut the bracket on throttle lever in pic 1 , thats for the return spring , it runs from that hole to the throttle cable bracket .
    The two threaded holes on drivers side are for mounting the solenoid that bumps up the idle speed when the a/c on . If you have no a/c , but have an onboard air compressor , you can get one to raise idle when airing up .
    That vacuum can on the pass side locks out the secondary door based on vacuum .
    Pic 3 , the thing on secondary throttle shaft is the secondary lockout , choke controls that , when choke comes off , the lockout moves out of the way .
    Pic 3 , the small vacuum cap line went to a vacuum can mounted on pass side rear of carb , not on every model .
    I don't remember what vacuum port went where , been a few weeks since I looked , will dig up the post I replied to with it if ya need it .
  11. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    sweet! thanks stranger! now i have a good idea what to do :bow:
