Very odd starter flywheel problem - help pls
Discussion in 'The Garage' started by crawlink5, Mar 13, 2005.
  1. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    I have a 78 Blazer with the factory 400 sb. It had a th350 trans Kcase from the factory and I put a 700r4 in it but didn't touch the flywheel. It looked new.
    When I bought it a year ago it started ok but the starter made a noise like it needed shimming (was loud) - I ignored it until the bendix went out with age.
    I replaced the bendix and stuck it back on. The gear and the flywheel does not mesh close enough to turn the motor over. Went and bought a new starter. Still same problem. Screems like a banshee but doesn't mesh - the gears just touch at the end of the teeth.
    Could that be a wrong flywheel? The flywheel on it looks new enough that it could have been changed out. The motor is balanced correctly as it doesn't noticably vibrate that I can tell. did the 400 have a little bigger flywheel like an extra 1/4 on the diameter? I do believe their was balancing issues like internal and external.(?).
    I looked at the threaded mounting holes in the block and didn't see anything out of the ordinary.
    Any ideas?
    Thanks,
    Doug
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    there are 2 different sized flywheels for small blocks(153T and 168T), sounds like you have the smaller one, to be sure, count the teeth, mark one, then count while turning the motor by hand, I bet you have a 153T one in there
    count and post back
  3. sweetk30
    Nov 1, 2004
    25,543
    539
    horseheads , ny 14845
    also the 400 is external and i dont think thay make a 153 for a 400. unless someone has balenced the smaller flywheel or the crank internaly.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you will have to go with whatever diameter flywheel you have
    if small then go with straight across inline bolt nose starter
    if large flywheel then go with staggered
    im sure this is whats going on is you have wrong wheel and starter nose cone issue
  5. dave_90_blazer
    Jan 1, 2004
    688
    one thing about this , is , there is a wieght plate you can bolt dowm along with the flywheel to add the neccessary counterwieght, allowing any SBC flywheel to be used
  6. skink4president
    skink4president Registered Member
    Mar 5, 2005
    79
    orlando
    I have a very similar problem on my '73. Check the teeth on your flywheel again to see if they're tapered. If so, you may need to replace the flywheel.
  7. crawlink5
    Oct 9, 2003
    431
    Spring, TX
    Teeth are like new. I guess Ill have to count. What should I ask (year, make, model) for on the other nose cone? I now have staggered.
