very quick question.. Whats the difference between warn standard and premiums?
Discussion in 'The Garage' started by camarossguy2, Feb 23, 2005.
  1. camarossguy2
    camarossguy2 1/2 ton status
    Aug 10, 2004
    214
    ABQ NM
    I searched for the last 20 mins or so, not luck in finding and answer. all i noticed was when anyone asked, everyone said "warn premiums all the way"
    whats the difference?
    I ask mostly because i have both, and the look identical. Of course the dial on one is black plastic, and the other is metal, but that never breaks, so what justifies the $50 difference?
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    296
    Truckee, CA
    i remember willyswanter saying somewhere that the difference is just that knob....
    He said all the internals are the same.
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I couldnt really find a difference either other than the knobs.......the premium knob is metal and turns about 3/4 turn to engage. The standard knob is plastic and turns about 1/4 turn. Ive noticed several tube chassis rock buggies with standard hubs so I figured if it works for them it'll work for me. So far I havent broken a standard hub yet :dunno:
  4. camarossguy2
    Aug 10, 2004
    214
    ABQ NM
    Then why is one almost double the price??
    I prefer the 1/4 turn over the 7/8 turn definatly as well, people need to start recomending the standards as well around here, but after i sell the premiums lol
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The premium come with a lifetime warranty.
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Not true, seen it a few times. Turning farther is better too, though I can't think of how to explain it exactly.
  7. camarossguy2
    Aug 10, 2004
    214
    ABQ NM
    link might not work http://www.partsamerica.com/SelectParts.asp?parttype=1335&ptset=A&searchfor=Hubs+-+4WD
    According to advance and autozone, they both have 1 year warrantees
    Im looking at them now, they both function identical...when you turn the knob it simply puts tension on a spring witch pushes on the center gear. if the gears are syncd, or as soon as the wheel moved slightly the gears will mesh and the center gear just slides in to the outer gears splines, thus lockign it. there both identical inside, same metals same pat #, its just the cap.
  8. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    linky no workie :dunno:
  9. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Well the premiums ARE lifetime warranty despite what autozone :rolleyes: says. And I think the 1/4 turn vs 7/8 turn is something along the lines of leverage...7/8 having more leverage to do the same job.
    I think you are also paying a premium for fit and finish as well, the premiums are nicers look hubs...not that a lot of people care about that on their wheeling truck.
    __________________
    '77 K5, Warn M8000, 402/350/203, 44/14bff, 4"/36" Irok's
    http://www.krazyk5.com
    http://community.webshots.com/user/trcksr4me
    http://community.webshots.com/user/trcksr4me2
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the internals are the same, but you can't put the premium caps on the standard hubs or vise verse. the thread size is different between the two and IIRC the premium has the smaller thread.
    i think the main diference is in the cap. after a while, ive had the standard hubs cap spin to lock going down the road, this was on a ford though.
  11. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    The biggest difference is sealing. I had warn "standards" and had issues with water getting in. I did not "wheel" the vehicle or go through water crossing. This was a DD/plow truck and after the winter I would check my u-joints and wheel bearings and I would have water contamination in the grease as well as signs of oxidation (assuming from the salt) on the inside of the hubs.
    I switched to premiums and had no issues.
    Also had a hub come unlocked in the standards........ It could have been that I did not engage it all the way (don't know for sure), but I like the "security" of having the furthur turn in the premiums than the standards.
    That being said: You could probably seal the standards better with some RTV around the housing, allen bolts, and put grease on the outside of the dial where it meets the housing to help prevent water intrusion.
  12. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    I went through three sets of plastic hubs before I went Premium. (no name, super winch, and Warn standard) The Warn standards MELTED on my first drive from Boston out to Colorado. I finally ponied up the money for the Premiums -after I had already paid for two sets worth :rolleyes:
    I managed to blow up one of the premiums...But it didn't matter! I took the blown up one down to 4wheel parts, they handed me a new one, and I walked out, no paper work or anything.
    -Warn Premiums all the way :cool:
  13. Kiqman
    Kiqman 1/2 ton status
    Dec 14, 2004
    102
    Portland Oregon
    Ask the Manufacturer
    I've been looking into new hubs. According to the WARN site there is a difference. www.warn.com
