vibes above 3000rpm...
Discussion in 'The Garage' started by Jonny-K5, Apr 6, 2005.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    ever since i installed my new trans i've noticed a slight vibration if i accelerate above 3krpm. as soon as it shifts it smooths out. its pretty slight, but i notice it. was glass smooth before. what could causs this? could it be the mainshaft in the trans? not sure how things are put together in an AT, so i dont know if this would be the case. only other thing i suspected was maybe the flywheel, but since it was fine before i figured that shouldnt have changed. any ideas?
    trans is a 700r4, new one is a different core, level 2 rebuild by bowtie overdrive
  2. BIG STEVE
    BIG STEVE Registered Member
    Jul 23, 2002
    66
    thornton colorado
    Shure its not exaust hitting some thing maybe takes that mutch torge to get it into some thing is it bad or just some thing differant?
  3. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i dont think its exhaust. its feels like a slight out of balance in the rotational mass. kinda shakes a bit. exhaust pipe vibe would typically just make a sound.
    didnt start til after i put the new trans in. nothing else on the truck was changed.
  4. BIG STEVE
    Jul 23, 2002
    66
    thornton colorado
    differant converter man some times that stuff will drive a guy nuts
    try un bolting the converter and rotating it 180 if that helps go 90
    ether way better worce you get the drift.
    The worst thing that happens to use is if a guy would buy more than 1 dozer/ loader whatever and shur as hell one would have a slight vibration or less power if he only got 1 he had no problem but i feel your pain.
  5. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i think i'll give that a try. thanks
