vibrating truck
Discussion in 'The Garage' started by LlanoK5, Oct 5, 2002.
  1. LlanoK5
    LlanoK5 1/2 ton status
    May 26, 2002
    202
    Llano, Tx
    When I start my truck (83 K5, 305, 465, 208, 10b). The engines idles rough enough to vibrate the whole truck pretty badly. It continues to vibrate till I push in the clutch, then it idles smoothly with no vibration. Does anyone have any idea what is causing this.
    Kirk
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    mine vibrates all the time, sorta like a harley
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    Maybe it's your throwout bearing that would explain the smooth idle with the clutch pushed in.hope this helps good luck
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    thats the way my dads 64 impala is..has a 283 with a 4 speed,,origianlly had a 2 speed power glide..his idles kinda rouch when its sitting there but smoothes out after you push the clutch in...when it back up it jitters a lot to..
  5. LlanoK5
    May 26, 2002
    202
    Llano, Tx
    If it is the throwout bearing, I hope it holds till I get everything for my hydro conversion. If it doesn't I geuss I'll just have to do throwout bearing and clutch without the conversion.
    Thanks,
    Kirk
  6. LlanoK5
    May 26, 2002
    202
    Llano, Tx
    For those interested, today I was talking a friend about changing my throwout bearing. We crawled under the truck and he said that might not be my problem. When I looked where he was pointing it seems that of the 4 bolts that holds the bell housing to the transmision there were 2 missing completly and one of the other 2 about to fall out. I got 2 new bolts and lock washers and now the truck doesn't vibrate anymore.
    Kirk
  7. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    really, i might check for tightness on my bolts, did your truck make a grinding sound when you start out in gear?
