Vibration after lifting blazer
Discussion in 'The Garage' started by mike2891, Aug 18, 2005.
  1. mike2891
    mike2891 Registered Member
    Apr 2, 2005
    8
    East Liverpool, Ohio
    Ok I just installed a 6" lift on my blazer & when i drove it to see how it was going to ride & when I gas it i get a real bad vibration. I checked to make sure my tires weren't falling off or anything because that was the first thing i thought, I didn't tighten the wheels back up... Other than that I haven't checkd anything yet to see what was wrong with it.... Is there any common or obvious things that it could be other than the u-joints? I figured my next day off I'll try the ujoints, but if that's not it i'm going to be clueless as to what I did wrong. Before the lift it drove and rode great with no noticable vibrations or anything
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    if it vibrates under acceleration then I'd check your u-joints.
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    Hi,
    This is a common problem with different solutions for everyone.
    Some suggestions would be:
    Use the search feature so everyone does not have to repeat themselves :D
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Driveshaft angles are likely the culprit if this is a new vibration. Your pinion angle is moving when you accelerate. You may need to add shims to your rear axle.
    Another thing to check is your driveshaft length. Make sure you have more than a couple of inches in the tail housing.
  5. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Mine vibrated after adding a 4" lift. I bought a new drive shaft with a CV joint. Problem solved.
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You should use the search feature. How did you lift it? Does it vib less in 4wd? How are your tcase/trans mounts?
    If you used a shackle flip, your rear driveshaft angles are WAY off. If you hear a "hitting" noise also you have a bad mount and yout tcase is hitting the floor. Did you lower the tcase? If it vibrates less in 4wd, somewhere on the rear driveshaft is where your problem lies. Taking off in 4wd puts less torque on the rear and can reduce a vibration on take off. Does the vibration get less at 40-50 mph? Or at any speed? If so you have an angle variation problem(driveshaft angle at rearend doesn't match driveshaft angle at tcase)
  7. Never Satisfied
    Never Satisfied 1/2 ton status
    Aug 21, 2005
    709
    Lafayette, Indiana
    Where did you buy the CV joint driveshaft?
  8. blackcherryK5
    blackcherryK5 Registered Member
    Aug 15, 2005
    9
    Kewane, Illinois
    my 89 k5 had this problem with a 3 inch lift turnes out the angle of the driveshaft was to much on it when i added some shims to make the angle a little less it stoped
  9. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Rye Valley Oil and Gear
    5807 Charlie Taylor Rd.
    Sugar Grove, VA 24375
    866-793-6451
    Ask for Ronnie. They were recommended to me by a local truck shop so I called them. Got the part in, and my truck drives perfectly now. Very good experience. Good luck.
  10. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    some people use spacers to drop the t case a bit but not my choice HAD call jesse
  11. blackcherryK5
    Aug 15, 2005
    9
    Kewane, Illinois
  12. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
